no 1st or second gear? ? ? ?
Old Apr 25, 2009 | 05:58 AM
nova_ss672001's Avatar
Default no 1st or second gear? ? ? ?
ok so i installed ma southbend stg.3 clutch and 17lbs. flywheel, bolted everything up and double checked everything...
i took it out for a test drive and it seems like i cant co into 1st or 2nd gear? ? ?
3rd 4th 5th and reverse all work though????
any ideas on what caused this? ? ?
01' 1.8t quattro 5speed....
Old Apr 25, 2009 | 10:46 AM
Mike-2ptzero's Avatar
Check the shift linkage where it bolts to the shifter arm coming out of the transmission. Make sure you got the bolt into the small hole on the arm when you tightened the bolt.
Is it just that you cant get the shifter into 1st-2nd, like you are being locked out? If so also check the shift linkage pivot bolts that are on the sides of the transmission. I had one break on me causing the linkage inside the transmission not to slide correctly keeping me out of 1st and 2nd gear. They pivot bolt head is a 12 point IIRC. If you need pictures showing the location of the 2 bolts let me know, I have 2 transmissions sitting in the garage.
here is what it looks like when its broken.
Old Apr 25, 2009 | 12:23 PM
well the shifter feels weird and the shifter goes all the way to the left but instead of first it goes into 3rd like it sputters and tries to stall if i dont give it enough as....
yea if you got those pics i will appreciate it dude....
Old Apr 26, 2009 | 12:33 AM
If you are going into 3rd when pushing the shifter to the left your shifter has moved or your shift linkage isn't set right. Check to see how the shifter sits while in neutral, if its sits different then you didn't put something back correctly. I will take pics of the bolt locations tomorrow.
Old Apr 26, 2009 | 05:50 PM
i fixed it.......
it was the linkage....i didnt put it in the whole right and it was sliding off or something....
thanx anyways for your help once again....
Old Apr 26, 2009 | 07:25 PM
Originally Posted by nova_ss672001
i fixed it.......
Glad it was something simple. I just got done pulling my transmission, just need to put the new one back in.
Old Apr 26, 2009 | 10:16 PM
yea dude me too.....
p.s thanx for the clutch nd fw deal....
so far it feels awesome cant wait till ma break in times over so i can do some WOT launches
Old Apr 26, 2009 | 11:04 PM
Cool. Let me know if you have any questions about anything and how it feels once the break-in period is over.
Old Aug 7, 2009 | 12:47 PM
apsbainc's Avatar
Exclamation same thing
I am having the same problem with my tranny, I tried messing with the linkage under the boot to no avail, those pics of where the bolt is supposed to be with the tranny and all that would be quite useful (I know this is an old thread... but worth a shot)
Thanks
Old Aug 7, 2009 | 08:52 PM
Here you go.
Slider bolt on the driver side. It is located just behind the slave cylinder for the clutch.
Slider bolt on the passenger side. It is located just behind the front axle flange.
