no boost
Old Nov 28, 2008 | 02:24 PM
dylsaudi's Avatar
Question no boost
Hi, new to site so sorry if this has been covered elsewhere, but i could not find it so here goes.If my DV is shot on a 96 1.8t could this cause the car to have no boost at all accompanied by some whining/howling noise? Icould not find any loose/split pipes.Cheers
Old Nov 28, 2008 | 02:32 PM
Jc61990's Avatar
that may be a boost leak.. or a blown turbo... if it sounds like a dentist drill.. i mean a loud one.. then your turbo is done.
http://www.youtube.com/watch?v=XSEFU...eature=related
Old Nov 28, 2008 | 03:58 PM
dylsaudi's Avatar
could the turbo blow just like that, The car has never seen more than 10psi and the problem was instantanious when pulling away. Its not smoking or anything. could a shot dv cause boost to leak back into the system?
Old Nov 28, 2008 | 07:05 PM
Jc61990's Avatar
whats your mileage... Turbos don't last forever.
Old Nov 28, 2008 | 10:28 PM
ghost6303's Avatar
usualy when turbos fail you know about it, either by the cloud of smoke behind you or very apparent noise. a dv could do that i guess, go pick up a 710n DV for $40. you need to do this if you are chipped anyway.
do you have a boost gauge? what does it read? how do you know your not getting boost?
Old Nov 30, 2008 | 11:26 AM
dylsaudi's Avatar
ok, Turbo is totally shot..found fault to be no oil feeding into turbo, so as you can imagine it went from a whirr to a clatter in 0 time.also accounts for not blowing smoke out of exhaust as no oil to turbo.Oil pipe from filter housing to turbo was blocked solid ?? Now that I need a new turbo, is there any benefit in fitting a k04/k03s over the k03 to a stock motor/ecu with the veiw to tune at a later date as I dont have the finances to do it all together
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
