No communication link with the OBD II connector?
Old Jan 2, 2019 | 05:11 PM
Christopher Stover's Avatar
Default Did you regain CEL? And data link?
Originally Posted by Luis401
After tune up (coils and spark plugs) my car 2001 Audi TT quattro 180hp will not start. After so many cranks my Battery started to drain. I tried jumping to my Nissan 2014 Murano and still car will not start. Tried removing radio fuse due to aftermarket Alpine radio (which has been working perfect before attempting tuneup) and nothing. Also tried removing the ABS fuse and all my car does is try to start as if there is no gas (Tank almost full). I should mention when ignition is turned I can hear a noise which I am assuming the gas pump priming. Car has been running and starting perfect before attempting tuneup! WTF..now I can't read fault codes because scanner can't read from odb port which displays "No Link" error! Please help.
Update: Also noticed my CEL does does not come on, found fuse #10 is blown which has something to do with info from coils and fuel pressure (read that in another post) so I will replace fuse, then I will put the OEM coils back on (ebay performance coils may have to strong of a signal ) therefore blown fuse, cross my fingers! Hopefully I can get a reading from the obd port.
Update. Replaced blown fuse and original coils now car starts up perfect on first attempt. The performance ignition coils kept blowing fuse #10. Stick with OEM coils!
were you able to get codes after that?
TCinJ
Jun 28, 2012 06:59 AM
batoloco666
May 10, 2011 07:23 PM
S4wanabe
Mar 27, 2009 06:12 PM
hylysly
Apr 9, 2008 11:47 PM
hylysly
Apr 8, 2008 10:38 AM
