no headlights
Old Feb 5, 2012 | 02:40 PM
gilraine's Avatar
Default no headlights
I have a 98 A4 Quattro 1.8t. I have no low beam headlights, pull back and the highs work.. did the clean the contacts trick, fixed the melted parts so the contacts move freely, but still no headlights? could it be anything else other than a bad switch??
Old Feb 5, 2012 | 03:35 PM
Skythe's Avatar
When you clean the contacts, did you make sure the actual metal part wasn't pushed downward? Sometimes the springs get stuck after being pushed down and need a slight pull upward. For every time that I've had to do the combi switch fix, I've had to pull the spring up regardless if the contacts needed cleaning or not.
Old Feb 5, 2012 | 03:48 PM
sb301's Avatar
Fuses
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
