No Map?
Old May 24, 2008 | 12:37 PM
bb4_96's Avatar
Default No Map?
There is no provision for a map sensor on myfactory intercooler and no map to be found. Is this right?
Old May 24, 2008 | 01:41 PM
cincyTT's Avatar
I'm make believe
Default RE: No Map?
If you have a 99.5 and older AEB engine, you dont have a map.
Old May 24, 2008 | 02:44 PM
bb4_96's Avatar
Default RE: No Map?
so i don't have to do a diode mod? Is my boost governed at all then with respect to limp mode?
Old May 24, 2008 | 02:47 PM
cincyTT's Avatar
I'm make believe
Default RE: No Map?
You cant up the boost on a AEB w/o a chip, if you do, it will run like **** and risk damaged. Just leave it be and get a chip
Old May 24, 2008 | 03:04 PM
bb4_96's Avatar
Default RE: No Map?
I've got a GIAC but i dont believe it is the GIAC+. Will that work. It already runs at about 16-17psi
Old May 24, 2008 | 03:16 PM
cincyTT's Avatar
I'm make believe
Default RE: No Map?
then you dont have to put a diode on the map, just add on the mbc and turn up the boost to what you wish.
