no power
Old Jan 14, 2013 | 01:25 PM
q139's Avatar
Default no power
a4 1.8 adr has no power and also backfires at 2000rpm if i step on pedal.
What can cause this?
Old Jan 14, 2013 | 01:26 PM
CCA4's Avatar
Need more info. What does "adr" stand for? Any CEL or trouble codes? Any modifications to the car?
Old Jan 14, 2013 | 01:37 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
It is most likely misfiring, not backfiring. Since it happens under load I suspect the coil packs or ICM have gone bad.
You should scan for codes so we can diagnose the problem. You can buy a VAGCOM cable on ebay for $5, or take it to a parts store to be scanned (if your state allows that, can't do it in CA.)
Old Jan 15, 2013 | 01:22 AM
q139's Avatar
I did vagcom scan and no trouble codes, also did datalogging and all was norrmal exept intake air temp sensor was 19,5 but i think early ones didnot have it.
3,5 g/s airflow at idle at load also logical,coolant temp sensor fine, lambda seeemd fine etc.
ADR stand for engine code.
I think 1 spark plug wire is not best but how do i check coil pack other than resistances?
and ignition control how to check thatone? do i need to do oscilloscope tests primary coil wires?
Old Jan 15, 2013 | 07:14 AM
CCA4's Avatar
Ahh that's where I got lost, ADR isn't a US-spec engine code. Where are you located? That's a non-turbo petrol engine, right?
Old Jan 15, 2013 | 08:06 AM
q139's Avatar
yes , i am in europe , estonia
Old Jan 15, 2013 | 08:25 AM
CCA4's Avatar
Do you see a flashing check engine light when the car misfires or backfires? Seems odd there wouldn't be any codes or anything, that sounds like more than enough to upset the ECU
Old Jan 15, 2013 | 11:06 AM
q139's Avatar
gives this sometimes
1 Fault Found:
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
and thats it for now.
Old Jan 15, 2013 | 11:07 AM
q139's Avatar
if someone can explain please.
Old Jan 17, 2013 | 02:17 PM
q139's Avatar
so is it lambda is getting slow on updtes?
suuntotim
Jul 25, 2011 12:36 PM
99BlackA4
May 22, 2006 08:43 PM
