Noise with clutch in - clicking
Old Jun 17, 2009 | 03:37 PM
compmanben's Avatar
Default Noise with clutch in - clicking
I've got a fairly recent problem on my car - after I've driven the car for a while (more than like 20 minutes) and I'm letting it sit for a minute or two to cool off, I noticed that when I put in my clutch, there is a clicking noise that seems to follow the engine speed - it speeds up if I rev the engine. It doesn't always happen but it seems to happen more on warmer days. Any ideas? This is for the 1.8T listed in my sig.
Old Jun 18, 2009 | 01:33 AM
Tweaked's Avatar
Is it the original clutch and pressure plate?
Old Jun 18, 2009 | 08:02 AM
compmanben's Avatar
The clutch and flywheel were replaced like 30-40k ago.
Old Jun 18, 2009 | 04:33 PM
Tweaked's Avatar
Interesting. I assume a new throw-out bearing was also used...?
Sounds like you'll need to get someone under there while it's happening.
Old Jun 18, 2009 | 04:42 PM
compmanben's Avatar
Not sure about the throw out bearing, is that a likely part to cause this problem?
I'll try to get it up on stands and listen to it when I get a chance though.
Old Jun 18, 2009 | 05:13 PM
Mike-2ptzero's Avatar
Sounds like a throw-out bearing issue since the slave puts more pressure on it when you push the pedal in.
Old Jun 18, 2009 | 07:42 PM
auditech79's Avatar
general rule of thumb is, if the noise is there when the pedal is pushed half way down its a throw out bearing, if its there when you push the pedal all the way down, its the pilot bearing. More likely a throw out bearing though.
Old Jun 19, 2009 | 08:45 PM
compmanben's Avatar
OK great, thanks for the advice guys I'll look into a throwout bearing or pilot bearing.
Old Jun 21, 2009 | 12:34 AM
Tweaked's Avatar
Agreed.
Cocody18
Jun 15, 2013 06:38 PM
byrnedave
Oct 5, 2010 09:08 AM
freestyleski
Jun 18, 2007 05:19 PM
AdamBlackB5
Jun 12, 2007 10:00 AM
AudiJapan
Feb 25, 2003 02:28 PM
