Not going in 3,4,5 5hp19 Automatic
Audi b5 2.8 Automatic ZF 5hp19 going into reverse 1st and second but when it needs to go into 3 it sounds like it is in neutral when i take my foot of the accelerator and the car slow down to 20 KM/H it engage second, and can drive till it needs to go into 3d again
No fault codes on VAG-Com how ever the Vac Com show it is in 3d Gear
I ran it while the car is off the ground and it then went trough all the gears
I CHANGED the following
Transmission OIL, Shifter , Range selector switch , TCM (Was flooded with water)
Please Help
Please Help
You say no codes in VAG-COM. You are checking the auto trans controller? How about gear position, which VAG-COM will show as you move the shifter while the engine is off? Maybe there is still some wiring or connector damage due to the water.
TCossuto
Jan 25, 2009 07:10 PM
