OEM alarm help needed.
Old Sep 12, 2008 | 02:31 PM
chop999i999's Avatar
Default OEM alarm help needed.
About 6 months ago my key fob stoped working due to batteries. I would have to be almost touching car with key to unlock. Replaced batteries and ofcourse now they key lost its programming. I found doing some searching you need an extra key so I ordered it last week and when I got it I tried to program and didn't work. I also noticed when the key fob first stoped working when I locked the door the alarm led would go on and shortly after it stoping coming on. don't know what that means. Need help please. '99 a4 1.8t
Old Sep 12, 2008 | 02:52 PM
pologk04's Avatar
I'm not sure if yours works the same as mine as I have a 2001 2.8q, but here is how i did it. To reprogram my key all i had to do was stand next to the driver door, press either the lock or unlock button once (they say for one second), and then lock or unlock the door manually with the key. if everything is good with your key and its programmed correctly, this should work.
Old Sep 12, 2008 | 03:53 PM
Default thanks
I read something about puting key in 1st ignition position then locking driver side door manually then pressig the unlock button then wait 5sec and then press it again. Tryed that and nothing. Will try what you said tonight. Anyone else have any input?
desertsnake1991
Aug 28, 2012 11:07 AM
AudiBronie
Jan 7, 2012 06:23 PM
thenjd
Jan 23, 2008 04:00 AM
oscar_3
Apr 12, 2007 03:12 PM
batanguenio
Sep 26, 2006 07:07 AM
