offset for rims questions
Old Sep 19, 2008 | 02:22 AM
LightOnA4's Avatar
Default offset for rims questions
hey guys looking to pick me up some wheels.
right now im stock suspension but i have the parts to addon.
i have koni sport struts all around and eibach sport springs setup.
havent been installed yet.
but im looking at getting me some 18s.
heres my questions.
- offset? i dont want the tires viewable(to much) on the outside of the fenders.
- the wheels im looking at are +33mm offset
- also 18's fit with a 1.25 drop from springs?
- and will that also effect the offset?
thanks in advance.
pZ
Old Sep 19, 2008 | 02:59 AM
CAB509's Avatar
6th Gear
Originally Posted by LightOnA4
heres my questions.
somewhere around +35, but I've seen some that run pretty crazy offsets of like +5
should work
yes
not to my knowledge
thanks in advance.
pZ
I hope that helps a bit to answer your question
Old Sep 19, 2008 | 03:06 AM
qUaTtRoA4's Avatar
sounds like you will be fine....how wide are the wheesls and what size tires will you be runnin?...
your offset is fine...with a drop like that you wont have to worry about rubbing....
the ammount of tire viewable outside of the fender will depend on the wheel width...
if you go with 8.5" wide it will lne up flush with the fender....9" will be the tiniest bit of poke....
Old Sep 19, 2008 | 05:39 AM
Flip's Avatar
The size of the rim won't affect the offset. The offset is already set no matter how wide the rim you choose is.
LitoLinsangan
May 22, 2013 08:57 PM
IseeSlowPeople
Aug 23, 2010 12:04 PM
hhh1855
Mar 31, 2010 10:26 AM
2000turbo
Apr 25, 2008 08:54 PM
ScareGlower
Mar 14, 2008 03:26 PM
