oh boy
To realign throttle turn the key to the ON position and leave it there for 3 minutes. You should be able to hear faint mechanical noises coming from the MAF. That's a start, but I reckon you might have a deeper problem, caused by the modification and a misunderstanding with the ECU and the mod
and spam doesnt faze me. im here to learn
its scary when the mods let your thread run.
this is one of those times i would love to have devil chew up my thread.
and my VAG is in brooklyn ny. just checked tracking number
Hey man, I don't have anything useful to contribute towards your issue but I wanted to ask, can you make your future thread titles more meaningful? This helps out future forum members when searching for a particular problem. Thanks! :-)
yeah no problem chief. you got it
Do you have "secondary air flow too low" after the install as i had those codes pop up after i installed the g2 with the ecu flash. the car can be started without the ecu, but shouldnt be driven to prevent any damage to the car
touch terminals together is easy. remove both terminals possitive and negitive and hold them together for a few. i always used zip ties..
key on key off. remove negitive cable from battery. reconnect turn key to on poss. wait 2-3 minutes (you will hear tb buzzing with your hood up) try to start. if start is not achieved. key off, key on push gas pedal to floor hold for 30 sec release gas pedal start car.
i cannot say they work. t
[/QUOTE
