Oil bubbling when doing Boost leak check...?
Old Nov 1, 2009 | 05:04 PM
2fast4u66's Avatar
Default Oil bubbling when doing Boost leak check...?
So while back I tried to do a quick boost leak check and was in a rush and forgot to put the hose back on the check valve. Of course all the air came out as it was going in.
Today I had sometime and went to the store to get some pvc and pressurized the system. I pressurized it at the intake tube that connects to the maf and took off the pankcake valve and plugged it. Put 10 psi in the system but soon as any air was put into it, there are bubbling sounds from what sounds like near the oil pan. I took the oil cap off, and couldn't feel/hear anything and same for the coolant reservoir. Any suggestions? Searched but no luck and looked at some vacuum diagrams with still no luck of being able to tell what would cause this. Thanks for help!
Old Nov 1, 2009 | 10:33 PM
bbboy's Avatar
Member
Happend to me also, I heard other people experienced it. Don't know...interested to find out too.
Old Nov 1, 2009 | 11:25 PM
2fast4u66's Avatar
Only thing i can think of is the oil return line is getting air in it.
Old Nov 3, 2009 | 10:45 PM
pimphell's Avatar
could be seaping past the rings or the valve seals
Old Nov 3, 2009 | 10:47 PM
Andrew149's Avatar
could be a clog and oil is recirculating
Mike02A4
Apr 26, 2010 02:59 PM
flynnr
Mar 2, 2010 07:24 AM
huviduc
Aug 17, 2007 02:51 PM
onepoint8tee
Jun 27, 2007 04:38 PM
a4bsix
Jul 6, 2006 04:28 PM
