oil in fresh air side of turbo?
Old Nov 11, 2008 | 08:12 PM
chefboyarde's Avatar
Default oil in fresh air side of turbo?
2001 A4 1.8T. i'm getting oil in the intake of my turbo what part after air filter does oil run through?
Old Nov 11, 2008 | 08:39 PM
qUaTtRoA4's Avatar
oil runs through the turbo to cool it....
for some reason I always have a bit of oil on my pancake valve, which is connected to the side of the turbo inlet pipe....
Old Nov 11, 2008 | 09:08 PM
EpicWin's Avatar
completely normal to blow SOME oil. If you have blue smoke out the exhaust, time to investigate.
Old Nov 11, 2008 | 11:45 PM
cincyTT's Avatar
I'm make believe
Its called oil blow by. It comes from the PCV (positive crankcase ventalation). It comes in the intake as oil vapor and when the air cools, it turns back to oil. You will also notice that there will be oil in the ic and tb. Only way to stop this is with a oil catch can
Old Nov 11, 2008 | 11:57 PM
BaconBait's Avatar
It's normal to have a little oil. If there's pools of it, you may have a problem.
to3o
Nov 6, 2008 10:32 PM
fusnowtiger
Feb 20, 2007 09:58 PM
cred05
Feb 3, 2007 07:43 PM
sjp02s4
Nov 15, 2006 12:56 AM
