oil light keeps coming on??
Old Nov 6, 2011 | 07:13 PM
jdrubio's Avatar
Default oil light keeps coming on??
my 1996 a4 quattro oil keeps coming on. ive checked the dipstick and its full.
could it be a bad sensor?
it started doing it as soon as i cleaned my egr valve and took it out for a test drive.
Old Nov 6, 2011 | 07:26 PM
02A6Beau's Avatar
if it is the light that is just below and to the left of your high beam indicator light, it is an oil PRESSURE warning. if your oil level is OK, you may have an oil pump or sludge problem
or it could be a bad sensor
good luck
Old Nov 8, 2011 | 08:33 PM
jdrubio's Avatar
thanks for the help!
but i guess there is no way to check which problem for sure it could be. im the one that fixes any problems on my car, and dropping the oil pan doesn't sound like to much fun. haha
Old Nov 8, 2011 | 08:41 PM
NHolzschuh's Avatar
neither does Walking to school, Walking to work, Walking... anywhere..
and most assuredly Walking to a dealership for a new car
Old Nov 9, 2011 | 06:55 AM
02A6Beau's Avatar
get a manual pressure gauge. I believe that you can put it in one of the oil lines at the oil cooler. there should be a thread around here somewhere that lists what the pressures should be a different RPMs. That should let you know if it is a sensor problem or a genuine oil pressure problem.
hopefully your thread will catch the attention of one of the B5 gurus around here and they can give you something better.
good luck and let us know how it goes
Old Nov 9, 2011 | 11:55 PM
Mojo3's Avatar
is there any non pita way to check oil pressure on a 99 a4 v6? not trying to hyjack thread were both having the same issue. i believe the years are similar no? anyway id pay some for this info as mechanics want a ton to fix.. basically having beepa n flaahing light randomly.
rsmith1977
B7 Models
Nov 7, 2013 09:55 AM
wobblewoo
S4
Jun 17, 2013 05:28 AM
wobblewoo
B7 Models
Jun 17, 2013 05:27 AM
RS808
Aug 25, 2009 08:19 AM
RS808
Aug 23, 2009 10:44 PM
