Oil Pan Removal and pump/screen Replacement
Old Apr 8, 2013 | 04:07 PM
steve_g's Avatar
Thanks for the reply..
Think it would be worth the extra $$ to replace the screen/tube and the oilpump? Or are these pumps pretty heavy duty enough where the majority of the problem is in just the tube and screen being blocked up?
Old Apr 8, 2013 | 04:51 PM
MrSnickelsnizer's Avatar
Yup, like you were saying the tube is usually the issue and the rest of the pump is fairly meaty in design. However there is an oil relief valve i believe on the side and mine looked pretty gunked up in there. So if you are in there you might as well change the whole thing out. Wait a second yours is driven by a chain if i am not mistaken. Mine was not. Mine was shaft driven. I am not quite sure what the procedure for removing a chain driven one would be. I am sure there is a simple procedure to follow. I am sure it is my book at home. That is why people more or less asked you for your engine code. Different pumps.
Old Apr 8, 2013 | 04:55 PM
steve_g's Avatar
Oh I didn't realize that. I was just going off the picture from the ecs link.
I'll double check when I get the pan off, before I order anything!
Old Apr 8, 2013 | 04:58 PM
steve_g's Avatar
can you tell the engine code from the VIN of the car?
WAUDC68D41A117575 is the vin off my car.
Old Apr 8, 2013 | 06:06 PM
hartsoe1's Avatar
Open the hood and look at the top of the motor up front.
Attached Thumbnails Oil Pan Removal and pump/screen Replacement-atw.jpg
Old Apr 8, 2013 | 06:51 PM
tdepirro's Avatar
The engine is an AWM.
It would be wise to spen the extra dollars and replace the oil pump along with the pick-up tube/screen.
With the oil pan off, the oil pump can easily be removed by first loosening the bolt holding the chain sprocket to the oil pump shaft and then pull the sprocket off the pump. Then, loosen and remove the three bolts securing the oil pump to the engine block. The oil pump should just pull off at this point. To re-assemble, pull down on the oil pump drive chain and angle the pump and sproket to engage the chain. Continue to maneuver the oil pump untils it's legs align with the alignment barrels. Secure the oil pump with the three bolts, torque to specification (i do not remember the torque spec).
The amount of effort to get to the oil pump is too great to be worth the savings of just a few dollars, While the benefits and peace of mind, far outweigh the cost. Do it!
Old Apr 8, 2013 | 06:52 PM
Mad Cow's Avatar
If it's an '01 it's an AWM. The fastest and easiest way to tell is by the accessory belts, if there's a v-belt it's an ATW or AEB, if not it's an AWM.
Old Apr 8, 2013 | 06:57 PM
  #18
tdepirro's Avatar
BEFORE
NEW OIL PUMP
CLEAN PICK-UP
Old Apr 9, 2013 | 09:48 AM
  #19
steve_g's Avatar
thanks for the pics tdepirro!
What prompted you to replace the pickup tube and pump? Did you get the low oil light and hear the diesel sounds too? Or just trying some preventative maint?
Old Apr 9, 2013 | 03:05 PM
  #20
ECS Tuning's Avatar
Sponsor
Thanks for posting the kit!
If anyone has any questions let me know!
Jason
