Oil pressure high...could be related to coolant?
I recently changed the timing belt and now when I'm driving I noticed the oil pressure gauge is showing between 200 and 225, when usually is below 200. Is that a reason to be worried?
I also replaced the water pump, so when I put new coolant I had 2 different containers of 1 gl each: one had 100% G12 coolant, the other one was mixed(G12 and distilled water) and I added by mistake the one with 100% coolant. I put 3 qt and when I realized what I did, I just added some distilled water (about 1q). Should I flush all out and replace it with the mixed one or this should be a problem? Could the high oil pressure and my coolant mistake be related?
Thanks!
Thanks!
