Oil pressure high...could be related to coolant?
Old Mar 16, 2011 | 07:59 PM
vlado182000's Avatar
Default Oil pressure high...could be related to coolant?
I recently changed the timing belt and now when I'm driving I noticed the oil pressure gauge is showing between 200 and 225, when usually is below 200. Is that a reason to be worried?
I also replaced the water pump, so when I put new coolant I had 2 different containers of 1 gl each: one had 100% G12 coolant, the other one was mixed(G12 and distilled water) and I added by mistake the one with 100% coolant. I put 3 qt and when I realized what I did, I just added some distilled water (about 1q). Should I flush all out and replace it with the mixed one or this should be a problem? Could the high oil pressure and my coolant mistake be related?
Thanks!
Old Mar 16, 2011 | 08:31 PM
ImTheDevil's Avatar
No worries on the coolant as long as you're up to capacity. That oil gauge is oil temp, not pressure (if you had 200psi you'd have far bigger issues). That oil temp is probably fine.
Old Mar 16, 2011 | 10:38 PM
thanks for your reply!
86f250xlt
Apr 16, 2013 07:23 PM
Dallas09
Aug 30, 2011 05:57 PM
hahaha251251
May 30, 2008 03:14 AM
Kristjansson
Feb 11, 2008 10:54 AM
kaplar
Feb 1, 2005 09:53 PM
