oil pressure light??
Old Apr 9, 2010 | 09:44 PM
euroukie's Avatar
Default oil pressure light??
i have a 1997 audi a4 1.8t quattro...when I ever start driving about 10 minutes later the oil pressure light comes on...then i turns off after a couple of seconds..i was wondering what the problem is...and also i have a small oil leak
Old Apr 10, 2010 | 12:03 AM
Mike-2ptzero's Avatar
Might want to see if the sensor is bad, it is the one at the oil/coolant exchanger. Could just be a bad wire. If everthing is good then you might want to install a aftermarket oil pressure gauge/sender so you can see if it is actually low. Pressure has to be well below 25 psi to cause the light to come on and 25psi is about what our cars run at idle when the car is warm.
Dallas09
Aug 30, 2011 05:57 PM
ArmenB
Oct 11, 2008 12:23 PM
lfab500
Mar 3, 2007 01:33 AM
