oil on spark plugs?!?!?
Old Feb 7, 2009 | 10:25 PM
djblaize's Avatar
Default oil on spark plugs?!?!?
Hey guys i got this from reading another thread,what could be causing oil to be in my cylinders and spark plugs, and how should i go about taking care of it?
Old Feb 7, 2009 | 11:28 PM
TCossuto's Avatar
valve guide seals or rings. possibly valve cover gasket but not in your actual combustion chamber. I don't remember if you can remove the valve seals without removing the head (pressurize cyl with air) or not. If your unsure how to find out, bring it to a mechanic.
Old Feb 8, 2009 | 01:45 AM
Tweaked's Avatar
Spark plug well gaskets. Change the valve cover gaskets.
Not sure what engine you have, but this should give you an idea of what you need to change. The round gaskets go around the plug wells.
Old Feb 8, 2009 | 12:42 PM
TCossuto's Avatar
again though the oil will be very apparent under the coil pack, not burning out of the combustion chamber.
cwedholm1
Mar 13, 2010 11:47 PM
Eric_C
Dec 13, 2009 10:48 PM
hsbertiii
Jan 19, 2008 01:42 PM
domino877
Nov 28, 2007 09:09 PM
aerostatwv
Nov 22, 2007 07:20 PM
