okay soo i need help!!!
okay i was leaking power steering fluid and the error code on my dash was is 1n1 and when i start the car i hear a loud whining noise whether im in nuetral or not so i put a new power steering pump on . but the noise is still there seems like it has gotten louder since i put the pump on
The ln1 is just a service interval that needs to be reset. After installing the pump (and I assume you used the correct PS fluid), you need to bleed the system. Step 1 is to turn the wheel from lock to lock a number of times with the car off (easiest if the front of the car is off the ground), then to turn the wheel from lock to lock a number of times when the car is off.
