one piece headlights electrical gurus
Old Apr 16, 2009 | 02:06 PM
audi_rob's Avatar
Default one piece headlights electrical gurus
Hi, i was just wondering if anyone has purchased the one piece headlights from ebay, the halo ones. The auction claims that no modification is needed but i the corner/blinker light connectors are not the same the seller wont reply so i have to modify the harness but im not sure how to go about it here is a picture of the connectors, the black one on the left is the one that came with the headlight and the one on the right is the one from my car two wires vs. three wires, is it possible to hook up the two wires with the positive, will that blow a fuse or do i have to use a relay? Any help would be appreciated
Old Apr 16, 2009 | 02:17 PM
ghost6303's Avatar
the stock one has 3 wires because 1 is a ground, 1 is for running lights and 1 is for blinkers. the stock bulb has 2 filiments in it. you need to get a multimeter and figure out which ones are used for the turn signal and splice those two wires into the new headlights. you will no longer have running lights on the front and one of those 3 wires will just be unused now. do not twist them together.
edit: alternately you can splice the positive wire that normally powers your running lights (the unused wire) into the power wire for your halos so they light up when your running lights are on.
Old Apr 16, 2009 | 02:23 PM
audi_rob's Avatar
Thanks for the reply, just wanted to ask is it ok to drive around without running lights? is that something i can get a ticket for? thanks
Old Apr 16, 2009 | 02:28 PM
ghost6303's Avatar
depends on where you live and what the laws are in your state. as long as your main headlights work no police officer would ever pull you over just for having no running lights, you would have to really be looking for it to notice. if you had to go thru a DMV inspection they might catch it, though i went thru the DMV in CT with no bulbs in 2 of my side marker lights and the guy didnt notice. in some place like Maryland or California where they go over your car with a fine toothed comb, you might get caught.
Old Apr 16, 2009 | 03:24 PM
audi_rob's Avatar
thanks for the help ghost
Old Apr 16, 2009 | 06:55 PM
Veegard's Avatar
Harnesses available online for a steep price, but worth it. Made mine myself by using old plug from headlamps, soldered it and put construction sealant in it. Was messy and looked shoddy even after a lot of hours. But it is possible
You'll have to cut through the backplate of the light to fit the modified plug also, if you don't buy an adapter.
You need to make new blinker adapters also.
Tourbo24
Oct 16, 2010 12:19 PM
jml-b5
Sep 29, 2010 12:10 AM
Dunzie182
Jun 19, 2006 02:07 AM
Big Blue S90
May 29, 2006 12:29 PM
brent07
Feb 4, 2006 07:18 PM
