one-touch roll-up windows = borked
if you look in your manual under the section about your battery it tells you that when you disconnect and reconnect your battery, you may have problems with one touch windows, ignition, and something else. it says how to make it work again (which i think is roll the window all the way down, then hold the switch so it goes up, and once its all the way up keep holding it for like 5 seconds or something). i dunno just check ur manual
I thought it was you had to roll them down then up three times for each window, and you should hold the switch for a second longer each way. It reprogramms the controler that needs to see the voltage and current chage when the motor reaches it's limits.
If i read the subject line correctly, you're telling us that your one-touch windows are:
Can't say that option came with my vehicle, but interesting to say the least.
yeah, that'll happen everytime you disconnect the battery. they'll start working again. i forget the exact method of getting them back, but just from using the windows a couple times, they start working again
I'm getting the vibe that the general consensus amongst us is that I need to roll them down, hold, roll up, hold, and they'll fix themselves.
I'll give it a shot. Thanks
