ordered a DV... now what
Old Sep 24, 2008 | 10:14 PM
flynnr's Avatar
Default ordered a DV... now what
hey everyone, i am getting chipped next week so i got a 710N DV and a boost gauge... i was looking at the DIY page and saw one for a pre 99.5 or something and i have a 2000... was curious if there are any good DIY for post 99.5 ? also... any recommendations on the easiest way to install a boost gauge? thanks a lot!!!
Old Sep 24, 2008 | 10:22 PM
Jc61990's Avatar
its really easy to install a DV
http://audizine.com/forum/showthread.php?t=17369
and boot gauge just tap into the vac line. in either spot numberd 1 and 2
i tapped into spot 1 on my car, just so i dont have long cables everywhere, and my gauge sits in my drivers side vent. i got power from the dial lights
Old Sep 24, 2008 | 10:26 PM
flynnr's Avatar
thanks a lot... but how do you get the wire from in the cockpit to the engine bay? is there a hole in the firewall or anything
Old Sep 24, 2008 | 10:27 PM
flynnr's Avatar
and AH i just looked at that DIY and apparantely thats different than mine is... (i have a 2000 and thats a 97) i heard they are in different locations and what not, let me know thanks a lot
Old Sep 24, 2008 | 10:28 PM
Jc61990's Avatar
i made a hole, ran through the trunk release switch, and pulled the gromet out under the hood and snaked it with a wire hanger... then i sealed the hole with silicone i had a really bad leak cause i didnt seal the hole at first
Old Sep 24, 2008 | 10:31 PM
Jc61990's Avatar
oh so then yours is like mine
jack the car up take off the skid plate and you will see one of these
pull it out and put the new one in, its way easier than the 97....
should look something like this
Old Sep 24, 2008 | 10:35 PM
Jc61990's Avatar
and if your looking down into the engine... its looks like this... circled
Old Sep 24, 2008 | 10:39 PM
hiwords's Avatar
you could also run the wire through the ECU box to avoid filling anything with silicone. if y ou take off your knee bolster and ecu cover, you can actually see light coming through so you'll have no trouble find the tube
Old Sep 24, 2008 | 10:40 PM
Jc61990's Avatar
that works too, and since your getting chipped, install your gauge when u have to take your ecu out
GarrettReid
B7 Models
Oct 20, 2010 01:38 PM
Mr. Phil
Mar 16, 2010 02:08 AM
TomRitt
Dec 15, 2005 12:42 AM
Firestarter1984
Jan 31, 2003 09:01 PM
