Outer door trim?
Old Sep 2, 2011 | 05:17 PM
Lornnn's Avatar
Default Outer door trim?
hi guys.. been a while
my first b5 is still in the shop as i gave up on my transmission problems. so far they've installed another and now the speedometer wont work and it wont go into 5th gear.. we'll see.
anyways, its time to work on my other b5 - same type 2.8QA/AHA - and get it cleaned up before the winter beats the **** out of it. right now the only issue is with the outer door trim. im not sure what this is called but its rubber, seems to snap into place, and in my case is falling off in two places:
front driver side
front passenger side
it doesnt snap back into place and im not all that interested in gluing it against the paint..
could you guys help me out with what this is called so i can either look into sourcing the two pieces or seat them back down correctly?
Old Sep 2, 2011 | 05:57 PM
ImTheDevil's Avatar
They're lower door trim moldings, aka "lowers". ECS sells them. You won't be able to snap them back on - the sleeves that the door clips slide onto are rotted. They're easy to change out.
Hansen27
Jan 30, 2014 01:33 PM
swamper8
May 9, 2011 08:13 PM
WSH
May 3, 2010 01:33 PM
nismonewf
Nov 27, 2008 08:43 PM
hyland
Feb 20, 2007 09:37 PM
