Overheats only on load
Old Feb 13, 2013 | 01:32 AM
jonbonesjones's Avatar
Moderator
True, but this is more of a core concept of head warping not being good.
Old Feb 13, 2013 | 10:48 AM
Jim_Coupe's Avatar
[QUOTE=hartsoe1;1424078]
Originally Posted by jonbonesjones
Theres your problemright there, not decking causes all sorts of unexplainable problems. Worked on a chevelle, had the same motor rebuilt 3 times because of over heating. Never decked the head. Once it was decked and done right, it works right....weird
JBJ, I hear you, but really, comparing anything on a historic US of A V8 and a German 1.8 has got to be a stretch.
Well ill start with the pump.. Then we shall se.. Ill be back how it went..
//Jim
Old Feb 13, 2013 | 01:33 PM
hartsoe1's Avatar
Hey experts, will the water pump blow out coolant if the thermostat is closed upon cold start up, in this scenario of removing the outlet pipe?
Old Feb 15, 2013 | 05:33 AM
Jim_Coupe's Avatar
hmm intressting thought !
Old Feb 16, 2013 | 02:58 AM
hiwords's Avatar
when the engine is cold, there is no coolant flow through the system. that's because the thermostat is closed. coolant starts flowing when the coolant gets hot enough inside the block to open the thermostat.
Old Feb 18, 2013 | 04:48 AM
Jim_Coupe's Avatar
On more symptom i have is thati lose coolant somewhere hmm..
lukescotty
Jan 23, 2012 09:27 AM
a4 quattro 1.8T
Jun 15, 2011 12:08 PM
CableGuy85
Oct 6, 2010 09:41 AM
DoCtOr-G
Nov 20, 2008 10:48 PM
bts_22
Dec 11, 2007 05:57 PM
