Pain in the a** lower radiator hose. Any tips getting it on completely?
Haha, sounds like I just need to hit up the gym. When I was changing the tie rod ends a while back one of them was practically glued on and wasn't budging. Luckily at the time the girl I was dating left for another guy, so I just took out my frustration on the tie rod end and it worked like a charm. Maybe I will have to find something to get mad about. Thanks for the input!
i didn't even lube mine....... i think it was the frustration that set in......... pull that ucker hard...... if that doesn't work take some speed or pcp or hell even some roids and get enraged
just keep at it....... it will go on, or go to a shop and throw the guy a 50 spot to do it
Could try some water-based lubricant, like astroglide
Could try some water-based lubricant, like astroglide or some wire lube such as Ideal Clear Glide.
IDEAL INDUSTRIES, INC. - ClearGlide Wire Pulling Lubricant
Probably wouldn't mess up the hoses too badly if they won't degrade latex condoms or PVC wire jackets.
But I would definitely use as a last resort in case it does degrade, then you have to do all that work over again just to replace a stupid hose.
IDEAL INDUSTRIES, INC. - ClearGlide™ Wire Pulling Lubricant
Careful, he might try to offer you a demonstration and put some in your trunk.
#19
the first one I ever did that I had a hell of a time getting off in the first place, but it was worse getting on , here's what I usually do NOW: Put a little vaseline on the seal inside the hose, clip closed, then push on until you here it click/snap on-mine go on like a dream now and don't leak. If you can't get the clip on, then it is not on correctly.
Getting it off, I usually soak it with lube too, something that isn't going to corrode the plastic.
