painting wheels..help!
Old Jun 18, 2008 | 01:14 AM
Soley4pres's Avatar
Default painting wheels..help!
so I just bought some s4 Avus 17" with great rubber off of a audizine member in SD to replace my 16" sport stockers. They have a good amount of rash on them with minor slashes and scratches.
I have a black A4 and I was thinking paint them black but leave the center caps stock silver. I need help though should I go
1)flat black and clear coat
2)semi gloss
3)gloss
or I was thinking if I could find gunmetal spray paint that would look good too.
any thoughts would be great..anyone with experience with auto spray paint as far as should I go with the glossier paints with or without clearcoat etc.
thanks alot..will be posting pics of the whole process when I finally decide
Old Jun 18, 2008 | 05:20 AM
Matt_Iliketurbopull's Avatar
Default RE: painting wheels..help!
Hi mate,
I'm a fan of black rims with silver or chrome etc, I'm not a painter, but for my 2 cents I'd consider a satin - semi gloss finish.
Old Jun 18, 2008 | 10:08 AM
sineo's Avatar
You will HATE how your wheels look when they are dirty if you go with anything besides full gloss. Use a high gloss paint AND clear coat. It will not be ridiculously shiny unless you wet sand between every coat.
Old Jun 20, 2008 | 12:03 AM
Soley4pres's Avatar
nice ..thanks! Any ideas on paint..I went to a few auto places but I couldnt find Dupli Color Black wheel paint
Old Jun 20, 2008 | 12:17 AM
sineo's Avatar
ORIGINAL: Soley4pres
I used Krylon Rust Tough Enamel. I recommend using that instead.
Old Jun 20, 2008 | 12:22 AM
Soley4pres's Avatar
cool thats what Ill go with..sanding wise sand after the primer coats and then before clear right?
Old Jun 20, 2008 | 12:31 AM
sineo's Avatar
You don't need to use a primer. I wouldn't. I only sanded before the first coat to smooth down some of the rough edges. The rims on my wheels are pretty chewed up in a couple of places, but the paint does a great job of hiding it. So far, the paint is holding up VERY well. I don't have a single chip on any of the wheels. Do a lot of coats of both color and clear.
Old Jun 20, 2008 | 12:40 AM
Soley4pres's Avatar
sounds good..I already bought a can of primer so I will do a light coat of that..I also bought some bondo like putty to fill in some cracks (there was more than I thought after cleaning them) so no sanding after the paint and before the clear coat?
Old Jun 20, 2008 | 12:41 AM
NickerdoodleAudi's Avatar
Wow, sounds like you know your stuff, Sineo!
Old Jun 20, 2008 | 12:53 AM
sineo's Avatar
I really would skip the primer. That Rust Tough Enamel is specifically designed to stick to metal and your primer probably isn't. As for the putty...I can't see that lasting on the wheels (different expansion coefficients), but I know that they do make metal filler epoxy and you can buy it at AutoZone...that would be your best bet if you really want to fill in some cracks, but you would be surprised by what manner of sins the paint'll cover or disguise.
You could sand very lightly with maybe 1500 grit between the final color and the first clear coat, but I didn't.
cantdrive55
Aug 5, 2009 12:52 AM
loopin
Sep 30, 2008 09:49 PM
acollicott
Aug 10, 2008 05:26 AM
andrewj654321
Jul 2, 2008 12:07 AM
droo587
Apr 9, 2005 01:14 AM
