Pics of my MTM engine bay!
I think that the K24 is good for up to 350 hp. The manifold is made by MTM and has good gas flow. I dont know where you can get hold of one now, but try MTM. It wont be cheap though.
Happy hunting!
Check immediately the turbocharger! DO NOT START THE ENGINE WITH THIS KIND OF PROBLEM! Remove the air inlet axial center hose of the turbocharger, in other words the compressor air inlet hose. Then check axial & radial gaps of the turbocharger rotor. Check also the turbocharger oil pressure supply. Check the engine oil level also. Repair & replace bad pieces. In the most cases the turbocharger is out of order when engine puffing off blue smoke and losing power.
Yes..... However it does not blow blue smoke on start up! So i am not sure whether it would be the valve stem seals. That is why i am confused....
Done the rest. All normal.
Not losing power though!!!!
