pics of the t3t4 setup...finally
Old Feb 5, 2008 | 08:23 PM
quattrosedan's Avatar
Default RE: pics of the t3t4 setup...finally
ORIGINAL: cincyTT
unless you run race gas or w/m, your not going to make 350awhp on 22psi. Its going to take atleast 25psi to get you there on pump. But dont forget that the turbo can do over 30psi. With the proper setup, you can reach 400awhp.
Well, from what I have seen I think that it can be achieved at 22psi with the correct fuel map, and most likely water inj. But I agree, the turbo will do much more, I just dont have the money to build the bottom end right now if it does go from running that much pressure..... [:@]
Old Feb 5, 2008 | 08:27 PM
cincyTT's Avatar
I'm make believe
you can make more power than most on a journal bearing turbo, but your still risking damage trying to push 350ahwp on stock rods.
Old Feb 5, 2008 | 09:24 PM
tdn's Avatar
tdn
when i asked about what you were running, i ment for the turbo. i mentioned i'm thinking about getting that turbo and wanted an idea of what you needed for it and how much it cost you.
Old Feb 5, 2008 | 09:33 PM
BaconBait's Avatar
Get the maf sensor away from the turbo.
Old Feb 5, 2008 | 10:01 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: tdn
turbo
manifold
dp
oil lines
injectors
sw
new hardware (nuts/bolts)
stuff for intake
total cost is $2500-3200 depending on parts used and where they are sourced
Old Feb 5, 2008 | 10:04 PM
BaconBait's Avatar
Coolant lines if it's ball bearing.
Old Feb 5, 2008 | 10:15 PM
cincyTT's Avatar
I'm make believe
you dont really need the coolent lines for gt turbos, but it helps.
Old Feb 6, 2008 | 08:45 AM
  #18
ORIGINAL: cincyTT
Yeah, for my gtrs, i had them disconnected and never had any issues.
And tdn, cincy hit it right on the nose. I spent right at 2500 putting the kit on.
turbo-700
manifold + flanges-300
downpipe- 100
oil lines-125
intake-50
if you need a new compressor outlet pipe- 50
misc hardware/fasteners-100
....then whatever tune you run with (1000 +-250)....puts you right at 2500-3000.
But I would highly recommend this setup over the previous gtrs setup, as spool time is not a huge difference (600-800rpms), and the power comes in much stronger. I am building a custom megasquirt standalone right now, and should have it on in the next month or so....then starts the real fun.....
Old Feb 6, 2008 | 01:48 PM
  #19
tdn's Avatar
tdn
thanks guys. after searching it seems like with the right tune it should be very reliable and inexpensive setup.. well compared to the apr stage 3.
Old Feb 6, 2008 | 05:36 PM
  #20
cincyTT's Avatar
I'm make believe
if you think its to laggy, throw on a .48 and you should take off about 500rpms of lag
