The Pinch Bolt
Old Dec 6, 2012 | 05:11 PM
jonbonesjones's Avatar
Moderator
Originally Posted by hartsoe1
Just to be clear on the air chisel ( I don't have air tools), you are using the air hammer and a pointed attachment to pound the nut end back through, where I'll be trying to pound it back through with a sledge hammer?
Thanks for all the suggestions.
Yup except the air hammer is stronger, more consistent, and easier
Old Dec 6, 2012 | 10:06 PM
hartsoe1's Avatar
Originally Posted by DillonT
and i have that fcp kit too. i live right near them. make sure you have weight on ctrl arms before you tighten everything
can I eyeball the expected angle of the control arms, and torque it down without dropping it and loading the suspension?
Old Dec 6, 2012 | 10:30 PM
Moderator
no, do it right
Old Dec 6, 2012 | 11:59 PM
DillonT's Avatar
i tried air hammer. it wouldnt come out.
first install all the arms loosely so everything is held together. the one bottom control arm which has the joint facing up, place a jack under it, and jack the car up until it barely comes off the jack stand. preferably not at all but a tiny bit is ok. proceed to tighten everything up. i used open ended wrenches on the upper arms by strut. remember i think its 5/8" wrench can be used on 16mm bolts. just incase you dont have that size wrench. good luck, pm me if you have questions, i just did mine not that long ago and have lots of pictures
Old Dec 7, 2012 | 10:21 AM
ECS Tuning's Avatar
Sponsor
For those using the air chisel this is what you'll want to use.
Jason
Old Dec 7, 2012 | 10:59 AM
hiwords's Avatar
OP: put you car on jack stands then use the the jack to load the suspension by jacking it up by the lower control arms by the rotor.
Old Dec 7, 2012 | 11:22 AM
Moderator
another tip for loosening the pinch bolt. stick an impact on the bolt, not the nut, and tighten, loosen, repeat. I cracked one of mine loose that way, then air hammered it right out.
vgo
Aug 1, 2012 10:04 PM
raudi28
Aug 24, 2011 04:11 PM
bixing
Apr 17, 2011 05:58 PM
jchaffee1
Oct 20, 2010 07:25 AM
legendpilot
Mar 12, 2009 08:57 AM
