Piston Question
Old Feb 10, 2008 | 03:39 PM
  #21
khj677turbo's Avatar
Default RE: Piston Question
Ahhh, see if i go big turbo it would probably be a gt30, but thats down the road... however, what would a 9:1 compression do to my ko4 tuning?
Old Feb 10, 2008 | 03:41 PM
  #22
cincyTT's Avatar
I'm make believe
Little. You probably wouldnt notice a differnce. With the lower c/r, you could run a couple extra psi on pump safer. I dont really see going anything below 9:1 since when its basically a street car.
Old Feb 10, 2008 | 04:10 PM
  #23
But I wouldnt have any fueling issues? I really know little on how compression can effect things. Is there some reading you could direct me too?
Old Feb 10, 2008 | 04:19 PM
  #24
chaos92287's Avatar
nope, lower compression allow you to run higher boost before detonation
Old Feb 10, 2008 | 04:53 PM
  #25
Ok, so it seems like lowering the compression a bit wouldnt hurt. But it seems that if i want Mahles im going to be spending atleast 600 dollars. Any opinions about Wiseco pistons?? They come with rings and everything.
Old Feb 10, 2008 | 05:21 PM
  #26
chaos92287's Avatar
thats what cincy is using in his 2.0 they are very good pistons
Old Feb 10, 2008 | 05:23 PM
  #27
cincyTT's Avatar
I'm make believe
Yep. The do come with all the rings and there are many people running them. Mine also have the skirts coated. Thats another $75. its basically to cut down on friction and increase the longevity of the pistons
Old Feb 10, 2008 | 05:39 PM
  #28
Where did you get that done? Or is that an option from Qed?
Old Feb 10, 2008 | 07:14 PM
  #29
cincyTT's Avatar
I'm make believe
I got mine from pagparts. Arnold had the set in stock and i just went ahead and got them. If you order them like that, you would probably have to wait a week or 2 extra for them.
Old Feb 10, 2008 | 08:39 PM
  #30
Hopefully i can find a set of pistons in stock, i dont need a month downtime [:'(]
