please help my baby a4 2.8 1998
Old Nov 19, 2008 | 09:23 PM
roll4ever's Avatar
Default please help my baby a4 2.8 1998
hey everyone, so i lost my key a couple of days ago and had to break into my car with a coat hanger. after i got inside my alarm went off and i popped my hood and disconnected the battery. i got my key today and i hook the battery back up. as soon as i turn my car on i hear a weird kinda grinding groaning noise and when i turn the wheel its even worse. this is making me suspect the power steering pump. i checked the reservoir and it had fluid in it still. do you think it could be anything else and if this is it where should i buy the part
Old Nov 20, 2008 | 12:19 AM
roll4ever's Avatar
does anyone have any suggestions?
Old Nov 20, 2008 | 12:31 AM
a4nick's Avatar
Is it a high pitch whining noise?
Old Nov 20, 2008 | 12:39 AM
roll4ever's Avatar
its not really high pitch it sounds like it did when one of my power steering lines broke. but there is still fluid in the reservoir that is why i think its the pump
Old Nov 20, 2008 | 12:43 AM
qUaTtRoA4's Avatar
try flushing your p/s fluid...
you should be running pentosin Ch11 (green can)...the previous owner could have put the wrong kind of fluid in...or your fluid could be bad...
I have heard it suggested in the past to replace your fluid every 2 years...
first thing you should do is flush the system, if the groaning continues, then you probably will need to replace your power steering pump...
get on it asap, because if your rack is not getting proper lubrication, you will be looking at a much larger bill...
gl!
Old Nov 20, 2008 | 12:46 AM
roll4ever's Avatar
ok ill flush it tomorrow to see if it gets better
a4nick's Avatar
Flush your power steering system and fill it with pentosin if its still making the noise then its probably your pump
Old Nov 20, 2008 | 12:47 AM
roll4ever's Avatar
thanks guys
DOC_DEPALMA
Mar 26, 2012 10:35 PM
munkee
Jul 6, 2009 04:57 PM
packman1
Apr 21, 2008 05:59 PM
Carlos10704
Mar 27, 2008 02:50 PM
Chef
Oct 19, 2006 07:18 AM
