Poke?
Old 12-30-2009, 08:07 PM
NickBroderick's Avatar
I'm not fully clear on offset. 15 - 17 would be poking a little? I'm still learning so could you explain a bit more?
  #22
Old 12-30-2009, 08:31 PM
Mr. Phil's Avatar
im curious now... i see a lot of pics with merc rims on the cars... are they a direct fit? and if not how are people getting them on there? does it change the ride or anything?
sorry if im thread jacking... pm me if u want so this doesnt get off topic
  #23
Old 12-30-2009, 08:36 PM
aledelic42's Avatar
15-17 would be poking a little. You should be okay with 25-30 offset with 8 inches wide wheels.
the silver avant I posted is pretty flush (maybe a few mm little past flush) with 8.5" et21. 1/2" is about 12mm so for the same look as that with 8" wide you'd need ~et15.. right?
offset is how far in/out the wheels are. spacers will change the offset. for example if you have a 17x8" wheel with an original offset of 35 then add 20mm spacers to it, the final offset will be 15 (35mm-20mm). if the width is 8.5" instead of 8", it will stick out a quarter inch farther, at least for one piece wheels.
mercedes wheels are mostly also 5x112. they should be direct fit after hubcentric rings. the older ones (pre early 2000s?) use 12mm bolts instead of 14mm so they may have to be redrilled to fit.
  #24
Old 12-30-2009, 08:51 PM
Mr. Phil's Avatar
well the reason i ask is cuz i found this... would these bolt on directly?
http://losangeles.craigslist.org/wst...531194067.html
or preferably these... but there is no info on the bolt pattern
http://losangeles.craigslist.org/wst...530085755.html
  #25
Old 12-30-2009, 11:41 PM
codymack43's Avatar
The second ones look wayyyy better.... i just think it'd be weird to have the cedes rims on the audi... unless you could change the cap out?
but other than that i think it'd be strange lol
sorry phil
  #26
Old 12-31-2009, 12:30 AM
Mr. Phil's Avatar
sorry for what? its my car not yours lol... im doing it for me not others haha
  #27
Old 12-31-2009, 12:41 AM
codymack43's Avatar
lol i know just dont mean to be dissin.
If you like it roll with it
  #28
Old 12-31-2009, 01:12 AM
kriptonik's Avatar
I'd consider the Avant to be poking instead of flushed. I'm running 18X8.5 with 25 offset in the fronts and they're sitting flushed to the fenders. I guess you're right, perhaps 20 (since it's 8 inches) or lower, depending on how much poke you'd want.
This is what I consider "flushed":
MrPhil - I'm not sure if the first ones will fit but I know the second one does as I've seen some people with those. aledelic has those and he's selling his set (IIRC).
  #29
Old 12-31-2009, 04:46 PM
Thanks a lot, that makes much more sense. I sort of understood the whole offset thing considering the definition for the word but the other stuff was japanese to me. Thank you!
  #30
Old 12-31-2009, 05:53 PM
B5 Audi's Avatar
just some others i thought phil might like sorry not on the topic
Merc sl500 17"
http://denver.craigslist.org/pts/1530595898.html
Audi A8 18"
http://denver.craigslist.org/pts/1525983087.html
Merc
http://denver.craigslist.org/pts/1524649345.html
Quick Reply: Poke?
