Poor gas mileage, please help
Have you done any maintenance to the car including; fuel filter, air filter, spark plugs, coil boots, oil change? I see a lot of broken vacuum lines around this mileage cause poor gas mileage along with lagging throttle response and poor idle. Are there any stored engine codes or recent codes causing a check engine light? We need more info to help
That message is at certain miles and will stay till cleared. The Maf and o2 readings can cause poor milage. Get some Maf spray and clean the element, replace the air filter and fuel filter then check milage again. My shitty 12v with awd gets about 22mpg combined to give you an idea.
If you are still really low, look for bad vac lines and consider new pre cat o2's
