Is it possible flash from AWM to ATW?
Old Jan 9, 2013 | 04:14 PM
KB3DXL's Avatar
Question Is it possible flash from AWM to ATW?
My ECU went bad (4B0906018P). I had a spare on hand (4B0906018M) that got my car running again, but not well. According to the part numbers, I put an ECU for AWM on my ATW car. Is it possible to use VCDS or any flashing program with the Ross-Tech VAG-COM to flash the 018M ECU to run an ATW engine, or do I have to find another 018P ECU?
Old Jan 9, 2013 | 04:51 PM
ImTheDevil's Avatar
You can recode to accommodate differences such as Quattro vs fwd or manual vs auto but I know of no reflash that would allow you to run an ECU from a different engine.
Old Jan 9, 2013 | 06:25 PM
redline380's Avatar
Legal Moderator
It would be like trying to install mac software on a windows. Not possible
Old Jan 9, 2013 | 11:31 PM
01 Avant's Avatar
you sure about that? and i mean the PC analogy
Old Jan 10, 2013 | 12:36 AM
redline380's Avatar
Legal Moderator
yeah i know its possible but not worth while. let me think about a better analogy... Converting awm to atw would be like trying to run Internet Explorer 9 on Windows 95. Good luck
edit- simpler analogy- try running 32 bit program on 64 bit. or for the computer illiterate, try putting a 2 inch pipe in a 1 inch hole.
Old Jan 10, 2013 | 01:11 AM
KB3DXL's Avatar
32 bit programs do run on 64 bit machines. But, enough with bad analogies. Here's my follow-up question:
It looks like my ECU went bad because of some sloppy soldering when the previous owner had it chipped. While that's being taken care of, my car is running on the AWM ECU and actually idles okay. It's just throwing a couple codes and not responding well to changes in throttle. If I'm only making short essential trips, and I'm not taking my car on long drives down the turnpike, or boosting high RPMs, do I run the risk of blowing the thing up.
Old Jan 10, 2013 | 01:34 AM
Mad Cow's Avatar
You'll need to wire in a wideband O2 sensor and remove the VVT through software and a resistor. You'd be best off finding an ATW ECU.
Old Jan 10, 2013 | 02:00 AM
KB3DXL's Avatar
Oh, I plan getting the ATW ECU fixed under warranty or replacing it. I just wanted to know if this temporary AWM ECU could cause any irreparable damage if I need it to get places for a week.
Old Jan 10, 2013 | 03:09 AM
redline380's Avatar
Legal Moderator
regardless of the prior analogies, an awm ecu will not work for your application. they are enitrely different. your atw operates on a narrowband o2 system. the awm operates on wideband. the sensors are different. i may not know my computers that well but i do know my audis.. and yes, the awm ecu will cause damages if operated too long. you can run it as long as you want. that doesnt necessariyl mean it is running fine. im surprised it runs at all. what is most likely happening is you narrowband ecu is reverting to predetermined fueling for your ecu functions. this means it is incredibly inefficient. you need to get the proper comptuer
Old Jan 10, 2013 | 07:33 PM
01 Avant's Avatar
i like that answer better
i was about to buy a PES tune from someone and found out it was for an AHA engine code and mine is a ATQ
I_B_Audi_S4_B6
Dec 2, 2011 12:35 PM
dkim
Nov 28, 2007 10:05 PM
Indiepunk
Aug 23, 2007 02:06 PM
ahgood
Jan 7, 2006 06:29 PM
