problem with oil dipstick
Old Sep 4, 2010 | 06:00 PM
mrdeeds23's Avatar
Default problem with oil dipstick
When I recently purchased my audi(01a4 1.8t), I went to check the oil on the dipstick and the entire dipstick holder came out. I got my oil changed today and they reminded me of it, they said they tried to fix it but it wouldnt stay where they thought it should be. The only problem is it's causing the dipstick to show a low oil level, and a little bit of frustration on my part.. anyway to fix this without taking it to a dealer?
Old Sep 4, 2010 | 06:54 PM
TeeterTawter's Avatar
its probably cracked at the base. its cheap and easy to replace.
Old Sep 5, 2010 | 02:15 PM
mrdeeds23's Avatar
Cool thanks ill look into that
Old Sep 5, 2010 | 11:44 PM
mrdeeds23's Avatar
I looked at the sleeve today.. it seems to be in tact and not cracked at all.. just seems like it doesn't fit right..
Old Sep 6, 2010 | 09:51 AM
CCA4's Avatar
Having just replaced mine last week, I can almost promise you that it's broken. There should be a clip on the side of it that attaches to a little arm thingy coming off the block, then a lip on the bottom that fits into the metal part of the tube coming out of the block. Mine was EXTREMELY brittle, and by the time i got done replacing it, was broken into about 20 or 30 pieces.
Old Sep 6, 2010 | 10:18 AM
NorthD's Avatar
Default dipstick
the outer tube at bottom is OK but the inner tube that goes into the oil chamber is a piece of garbage and that is what cracks Now some of the plastic will get into the oil but do not worry as it will not go anywhere vital.
Take small cover where dipstick is off and the two bolts the hold the flat metal plate then move the flat plate to right side almost flips over should be able to reach from there Item # 06A103663B
L8R........
Old Sep 6, 2010 | 12:13 PM
mrdeeds23's Avatar
that metal clip doesnt fit at all into the little lip on the sleeve. It's just twisted to the side and going down into the oil. Think the previous owner got the wrong replacement or something?
Old Sep 6, 2010 | 02:57 PM
CCA4's Avatar
Definitely possible. A new dipstick and dip stick tube are about $10 together from ECS, might be worth replacing them.
Old Sep 6, 2010 | 10:52 PM
mrdeeds23's Avatar
Hm okay well this is what they had and it matches up exactly to whats in my car. is there supposed to be anything else on the metal clip that the tube clip is supposed to clip in to?
Old Sep 7, 2010 | 07:19 AM
CCA4's Avatar
nope thats it. In your post that I quoted earlier, you mentioned that the metal is just twisted to the side or something right? That little metal arm should come out off the block parallel to the ground, then there should be a short 90* bend that clips into the dipstick tube. Take a picture of what you've got and maybe we'll be able to help you figure out whats goin on. Hopefully the previous owner didn't do anything dumb.
