Problems An Audi has @ 130K
Old Oct 30, 2013 | 08:13 AM
mtroxel's Avatar
Originally Posted by mrchicken
I'm assuming that the 271,000 mile car at least had the regulator replaced once or more?
Nope. Nothing. Same with the one in my signature. If the OP had complained about the rear wheel bearings I would have said "no s--t!" I can do those in my sleep. But his alternator problem is pretty uncommon for these cars.
Old Oct 30, 2013 | 10:25 PM
hartsoe1's Avatar
Originally Posted by Kamil`
I live in Queens in NYC and with these roads you should be happy if a brand new set lasts you a good 30-50,000 miles.
I'm talking to mimgq2, who appears to live in jersey. He has a laundry list of repair needs before struts. your drive around queens is n/a.
Old Oct 31, 2013 | 01:39 PM
Kamil`'s Avatar
Yea.. my car is N/A but what does that have to do with shocks and struts. His car may weigh slightly less than mine but I doubt my numbers are incorrect.
Old Oct 31, 2013 | 02:02 PM
MetalMan's Avatar
He meant N/A, like Not Applicable, not NA, naturally aspirated.
Old Oct 31, 2013 | 02:26 PM
Kamil`'s Avatar
I had a feeling. (facepalm)
Old Oct 31, 2013 | 04:04 PM
Mad Cow's Avatar
LCD problem is just a dumb thing in the B5 due to poor manufacturing. It's criminal that Audi didn't ever fess up to it and issue a recall.
I also had the blinker relay failure ... that is also just dumb, that should have never failed.
If VAG issued a recall for the something like the LCD it would have been 100% voluntary, sure it's super annoying but you don't just issue recalls nilly-*****. Now if the cluster had a tendency to burst into flame there would be a case, but as it stands there isn't any way a bad LCD screen would make the car dangerous or even affect its operation in any way.
I'm with you on the blinker relay though, it's amazing that they were able to screw up something so basic. Mine still works, but only when it's warm inside, it's actually kinda fun to watch it slowly come back to life.
Old Nov 1, 2013 | 02:07 PM
M5S5's Avatar
Tech Certified
With the alternator you have to question if the whole thing is failing or just the voltage regulator. The brushes in the regular can definitely wear out and I don't think there is anything unexpected about that. I'm assuming that the 271,000 mile car at least had the regulator replaced once or more?
Unfortunately it's not very easy at all to replace just the regulator without removing the alternator, although I saw one thread where someone claimed to do it. So you still have to take the damn thing out to fix it.
Recalls are for safety issues!
Why does every cheepo seem to think that because there 10 year old car has the same problem as every one else that the manufacturer should flip the bill? If you want a warranty buy a NEW car!
Old Aug 9, 2015 | 02:17 PM
  #18
mimgq2's Avatar
Default Audi A4 1.8t p0300 multi cylinder misfire
After 14+ years @ 150K miles I have to say good bye to my Audi......the number #4 cylinder exhaust valve cracked.......Causing a multi cylinder misfire..
In summary, I have to say I was not very happy with Audi .EVERY PARTS fails period...
Se Shig
Apr 22, 2015 09:46 AM
littleflavio
Aug 17, 2008 05:45 PM
gatorgamer
Aug 27, 2007 06:51 PM
vacowtipper007
Aug 2, 2007 09:45 AM
