Pulled some codes finally!
Old Jul 6, 2012 | 02:39 PM
DOC_DEPALMA's Avatar
Exclamation Pulled some codes finally!
Man getting VCDS setup on this laptop was a PITA! I've been away playing army for a while so here is what's happening with the old girl so far.
Rough Start and Misfire, also for some reason the ******* battery continues to kill itself. I got angry and tore out the alarm... (100 degree heat makin me crazy)
Anyway here's the codes, let me know what you geniuses think please! *cough* devil *cough*
VCDS-Lite Version: Release 1.1
Friday, 06 July 2012, 14:28:19.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D02
Coding: 01242
Shop #: WSC 02324
VCID: 2B2984AFCA0B
4 Faults Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 71-00 - Cylinder 4
17090 - Shareware Version. To Decode all DTCs
P0706 - 71-00 - Please Register/Activate
18021 - Shareware Version. To Decode all DTCs
P1613 - 95-00 - Please Register/Activate
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 95-00 - Unknown Error Elaboration
Readiness: N/A
Old Jul 6, 2012 | 04:28 PM
ImTheDevil's Avatar
Check your text
Old Jul 6, 2012 | 05:01 PM
Recoded the ECU as per ImTheDevil's instructions (thanks MetalMan). Here are the new codes:
Friday, 06 July 2012, 16:57:32.
Coding: 06201
Shop #: WSC 02324
VCID: 2B2984AFCA0B
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 91-00 - Unknown Error Elaboration
17828 - Shareware Version. To Decode all DTCs
P1420 - 95-00 - Please Register/Activate
17844 - Shareware Version. To Decode all DTCs
P1436 - 95-00 - Please Register/Activate
17878 - EVAP Leak Detection Pump: Electrical Malfunction
P1470 - 95-00 - Unknown Error ElaboReadiness: N/A
r--------------------------------------------------------------------------
Last edited by DOC_DEPALMA; Jul 6, 2012 at 05:10 PM. Reason: Explained source of new codes
Old Jul 6, 2012 | 05:10 PM
ImTheDevil's Avatar
P1602 (terminal 30 voltage too low) means the computer isn't seeing sufficient juice at output terminal 30 on the ignition switch. Probably from the alarm draining your battery - once you get some run time, long as your battery isn't toast, you'll be able to clear it for good.
P1420 worries me somewhat. I didn't think your 97 had an SAP but that code is for an SAP circuit malfunction. That could cause trouble at inspection time. Ditto for P1436 (SAP relay malfunction).
P1470 - EVAP Emission Control LDP Circuit Electrical Malfunction. Not sure what to say on this one, other than a vacuum or check valve failure of some sort. Hoping someone will chime in on it.
Old Jul 7, 2012 | 04:55 PM
Default I have a *****
Forgot to mention that the Devil and I recoded the ECU to where we needed it, he has since updated MetalMan's DIY in reference to the 12v 2.8 5 speed
Drove her around for a while today and got these 3 codes, and these 3 only
Saturday, 07 July 2012, 16:40:13.
Control Module Part Number: 8D0 906 266 B
Component and/or Version: 2,8l V6/2V MPI OBD2 D02
Software Coding: 01202
Work Shop Code: WSC 02324
VCID: 2B2984AFCA0B
3 Faults Found:
16688 - Cylinder 4: Misfire Detected
P0304 - 71-00 - Cylinder 4
16689 - Shareware Version. To Decode all DTCs
P0305 - 71-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 71-00 - Please Register/Activate
Has anyone any advice on where I should begin?
Right now I have the negative battery cable D/C'd for the TBA
Last edited by DOC_DEPALMA; Jul 7, 2012 at 05:05 PM. Reason: TBA Tattoo from The Devil
HiLandR
S4
Oct 2, 2014 10:09 AM
99A4BlackNGrey
Jan 19, 2009 10:59 PM
socalaudi
Jan 8, 2008 11:56 AM
qttrcoupe
Oct 26, 2007 04:36 PM
bmwtoaudi
Feb 22, 2007 11:18 AM
