putting gas in the tank at the pump issues lol
Old Feb 26, 2010 | 11:29 AM
jjcrt2's Avatar
Question putting gas in the tank at the pump issues lol
ok i have a 01 a4 1.8t well anyway every time i go to get gas i go to fill up and i obviously put 93 in it and ill put like a dollars worth of gas in and it'll cut the pump off as if my tank was full. so i have to take the nozzle out to relive the pressure and keep doing that over and over again until im done. is there some sort of check valve in the fill hose? im so tired of spending 20 minutes trying to get gas and ppl looking at me weird when the pump clicks like 74 times. any body else had to deal with this or no what possibly the issue could be? thanks.
Old Feb 26, 2010 | 11:38 AM
tware4021's Avatar
i have this problem too but only at certain pumps...id try a different pump next time and when it does this to me it lets me put in like .74 cents and then i do what you do and i get very upset with the pump
Old Feb 26, 2010 | 11:51 AM
dragonrage's Avatar
Sometimes holding the nozzle at different angle will change how that goes. I have to do that sometimes. I think I normally have to press down a little bit on the handle.
Old Feb 26, 2010 | 12:38 PM
Staticclism's Avatar
Jiggle the handle a bit or try pulling it out an inch or so and it should quit. Mine does that every now and again on some pumps and by changing the angle that the nozzle's at inside the filler neck and/or pulling out a smidge always seems to cure it for me.
Old Feb 26, 2010 | 12:48 PM
Baby Kito's Avatar
You have the pump in to far just hold it back a bit. Happens to me all the tome and that always works now
Old Feb 26, 2010 | 01:05 PM
Andrew149's Avatar
same here pull it out a inch and let it chill
Old Feb 26, 2010 | 01:45 PM
dragonrage's Avatar
...in bed?
Old Feb 26, 2010 | 02:09 PM
Andrew149's Avatar
haha what in bed noo just let it hang out a bit
Old Feb 26, 2010 | 03:09 PM
jjcrt2's Avatar
ha ive tryd all of those but no success so idk maybe one of these days ill find the right combo or trick thanks anyway
Old Feb 26, 2010 | 04:21 PM
y^0's Avatar
y^0
i know exactly what you mean, sometimes, those pumps are just retarded, i found that i have to stay with the pump and hold it just right, it's a pain, but it usually does the trick
