Quattro trans fluid
Old Aug 30, 2009 | 04:37 PM
NASHtyA4's Avatar
Default Quattro trans fluid
I've been searching and can't seem to find what fluid to use? I have access to alldata and it says to use 75w 90 but that is gear oil and doesn't seem right to me.. Can anyone back that up? I'm just looking for some fluid I can pick up at autozone and top the trans off with. The axle seal has a very, very slow leak if you can even call it that. But I'm pretty sure I'm low cause the tranny slips a little bit if I get on it. Thanks.
Old Aug 30, 2009 | 04:58 PM
A4Cragman's Avatar
Are you tip or 5 speed?
Old Aug 30, 2009 | 05:01 PM
NASHtyA4's Avatar
Oops! I meant to say tip instead of quattro. Haha
Old Aug 30, 2009 | 06:13 PM
david9999's Avatar
tip takes Pentosyn fluid, or Audi OEM.
Not gonna find it at pepboys and be prepared to shell out about 16 dollars a quart.
Also putting fluid in is a bit tricky as there is no dipstick. You need to have the car perfectly level, with the transmission slightly warm, either once around the block or check the temp with a vagcom and fill until it starts to leak out.
Old Aug 31, 2009 | 06:30 PM
NASHtyA4's Avatar
I know the procedure I was just hoping I could pick up some cheaper fluid at like autozone like I said just to top it off.
Old Sep 1, 2009 | 11:04 AM
punkrocker5817's Avatar
definitely dont skimp on tranny fluid. Go with manufacturer requirements.
tuttlebob
Dec 10, 2012 09:04 PM
Turkeybaster115
Nov 7, 2009 02:22 PM
Turkeybaster115
Oct 31, 2009 08:53 PM
mikeysentra
Dec 14, 2006 04:40 AM
wickedrelish
Dec 28, 2005 02:16 PM
