Question about this 1.8T custom intake setup...
Old Mar 26, 2008 | 02:03 AM
CampbellsChunkySoupr's Avatar
Default Question about this 1.8T custom intake setup...
http://forums.vwvortex.com/zerothread?id=2507093
I was looking at this and i think i found a filter that will work. is it essential to put a breather filter on that 1" hose? would i be fine getting buy without a filter for that? whats the purpose of that lower hose?
has anyone else done this? sorry. i didnt register on vortex yet and im a litte on the drunk side. so let me know what you guys think about this setup vs the drilling holes into your fender liner setup.
-Tyler
Old Mar 26, 2008 | 02:28 AM
feerocknok's Avatar
Default RE: Question about this 1.8T custom intake setup...
I had the intake box mod; just made some extra noise. Decided I wanted more noise so I run a cone filter behind a heat shield with the holes in the fender. I plan on making more fender holes. Run heater hose with a slit in it on top of your heat shield and it'll look professional. Skip out and it'll look ghetto.
My car makes that "pshhh" sound.
Old Mar 26, 2008 | 02:37 AM
mkay. well the problem is that i live in iowa and i read through all 50,xxx pages on that one thread about the DIY intake mod.
https://www.audiforums.com/m_260779/...14/key_/tm.htm
see, thats a problem in here iowa with the snow/slush/rain/gunk/goo/globby stuff. it just wont work for me to have water be anywhere close to my intake setup. so i was gonna try something like this. i have a cone filter for it. just need to know if i need the other bottom hose filter.
Old Mar 26, 2008 | 02:46 AM
turbo kraut's Avatar
Tech Guru
the filter on the "lower" hose is for your sap..... if you really are dead set on doiung the cone filter mod, use a filter on it...... i had that for a while, and all it really does is make your dv louder.... i went back to my swiss box and a k&n
Old Mar 26, 2008 | 02:49 AM
kk, and autozone/orielleys should carry something like that? and the site says $20 for such a small filter?!
will i be in trouble if i leave it with no filter on it?
Old Mar 26, 2008 | 02:52 AM
Tech Guru
i know it is loud.... and i am pretty sure you sill toss a code
Old Mar 26, 2008 | 09:17 AM
pimphell's Avatar
ORIGINAL: turbo kraut
toss a code with what? the intake? the sap filter? neither of them toss a code
Old Mar 26, 2008 | 09:19 AM
pimphell's Avatar
thats a decent enough write up that you found about the intake mod. thats preatty much what I did, mines cleaner though
Old Mar 26, 2008 | 12:33 PM
feerocknok's Avatar
We get gobbolty gook here too, and lots of it. No problems so far.
I'd run a filter on that line definitely.
Old Mar 26, 2008 | 02:35 PM
B5 owns's Avatar
The line is the intake for the secondary air injection pump which pumps air dirrectly into your engine at startup, so you NEED a filter for that. If your gonna run a cone filter, dont just slap it on the maf and think that your done, get a 180* pipe and do it like its supposed to be done. I wouldnt do any of these mods because there is no point to them unless your going BT. if you want the wooshh sound then just get a forge splitter.
