Question about replacing one tire
Old Mar 29, 2010 | 07:21 PM
Wvjon's Avatar
Member
Default Question about replacing one tire
I think i put this in the wrong place so i am reposting it.
I have a cut in the sidewall of my passenger side rear tire. I would rather not relive the stupidity as to how this happened. Suffice it to say that I had my head somewhere it should not be when driving.
So on to my question. I know and AWD car is picky about tire sizes being the same. My question is this: How much tire wear on the three good tires is enough to cause issues with this.
Next question: How do i measure tread depth other than with an actual gauge of some sort.
Thanks in advance.
Old Mar 29, 2010 | 07:55 PM
rockboarder's Avatar
Member
rule of thumb is you shouldn't have more than 3/32 difference between tires, so pretty much if you only have like around 5 thousand miles on your tires you should be ok but other than that you should probably replace all of them
Old Mar 29, 2010 | 08:09 PM
Wvjon's Avatar
Member
About 17k so Four tires it is YAY!!!
Thanks for the information.
Old Mar 29, 2010 | 08:33 PM
FASTER's Avatar
Tech Slut
^^^ Fvck that, jus replace two at most and put the new ones in the back, then rotate them to the front when the older two get crappy. There are wear bars you can tell the tire life by too, or one of those specialty tools called a RULER lol. FYI if awd systems were really that sensitive to size differences, then they would all come with full size spares...
Old Mar 29, 2010 | 11:27 PM
hauptjr's Avatar
What about the spare?? That's also a full sized tire - right? (on an AWD).
Old Mar 29, 2010 | 11:38 PM
Dallas09's Avatar
Yeah idk, like faster said the spare isnt full size. I had the same thing happen, and just tried to keep them similar tread on each side.. I never had a problem. Obviously you dont want to screw up the diff or something but nothing happened to me, 4 new tires isnt so cheap either especially if the other 3 arent in bad shape. I just got new tires at about 150,000 and i probably drove on the older ones for a solid 10,000, do at your own risk but I was fine.
Old Mar 30, 2010 | 04:14 AM
kriptonik's Avatar
Replacing two should be okay.
Old Mar 30, 2010 | 04:34 AM
joenelson7687's Avatar
I asked a similar question not too long ago. You can even have two different brands of tires, just as long as the tread life is close and the tire size itself is the same...
Old Apr 1, 2010 | 10:26 AM
Wvjon's Avatar
Member
I know they dont come with full size spares but I think the actual diameter matches.
Specialty tool called a ruler. Funny guy there. Thanks for the info. May just look into getting two.
Thanks for everyones opinion. Just didnt want to go by the tire guy he naturally thinks four new tires is the way to go LOL.
Old Apr 1, 2010 | 12:38 PM
CCA4's Avatar
yeah i would say two would be fine. I trashed a tire/wheel on a pothole a while ago, replaced two and rotated them and have been fine for about 10k miles so far. *knocks on wood*
A4 2000
Jan 3, 2012 08:13 PM
Armenian
Aug 18, 2010 10:14 PM
Wvjon
Mar 29, 2010 04:34 PM
madridlover
Dec 30, 2008 01:51 PM
a4r6
May 15, 2006 12:10 AM
