quick vacum question
re assembling intake side of motor. Its been apart for a while. Need to know if the vac line with the check valves goes to the bottom of the intake or on the back? it on a AEB motor, 1998.
Thank you for that. Im I refuring to the intake mainfold side of the motor. there is one line from the Tee part of the crank case breather tube. and them there is another with a couple check valves on it. those are the only two line im not sure if were they go.
