Radio Fob pairing problem
Hi guys,
I'm having the following problem when trying to pair my alarm system with with the radio keyfob:
I follow the following procedure.
spare key ignition on
lock drivers door with another spare key.
press unlock on the fob(lights flash)
wait 6 seconds and press unlock again (all doors unlock)
switch ignition off and take key out of door and ignition.....
As I understand the key should be paired now right? or am I wrong?
Pressing the buttons do nothing after the procedure... the central locking button also seem to be disbled...
its a '97 A4 Avant 2.8 Quattro
Codes from Vagcom:
Codes from Vagcom:
Code:
Control Module Part Number: 8L0 862 257 P Component and/or Version: CV-Pump, Alarm, RC D13 Software Coding: 13130 Work Shop Code: WSC 00070 2 Faults Found: 00955 - Key 1 09-00 - Adaptation Limit Surpassed 01134 - Alarm Horn (H12) 49-00 - No Communications
ffmist@hotmail.com
Aug 22, 2010 09:57 PM
