Radio/temp dash display out?
Old Mar 10, 2008 | 10:43 AM
briwill's Avatar
Default Radio/temp dash display out?
I was pushing the buttons on the dash display to set the clock and when I started the car back up the center computer screen in the dash cluster that displays radio info and temp disappeared. Is there a way to turn this back on or is my display bad?
Old Mar 10, 2008 | 11:35 AM
feerocknok's Avatar
Default RE: Radio/temp dash display out?
It's a button on the same stock as the mode selector, on the bottom of it. Turns the display on and off.
Old Mar 21, 2008 | 10:15 AM
Boedie's Avatar
Holy CRAP !!! [:-] I just though my display was out and I would have to replace the damn cluster. That button only says reset (and that is hard to see as it is anyway). I had no idea it actually turned the display on and off. TY soooooooo much for that little piece of info. It's back on now!
On another note, however.
1. My display has some lines that don't seem to work all that well.[:@] The screen is kind of garbled.
2. My Cruise Control does not turn on at all.
Are these related issues like a problem with the computer? Or is it 2 seperate things like the CC switch and then just the display going out and I need a new cluster anyway?
Thanks
Old Mar 25, 2008 | 12:44 AM
briwill's Avatar
The same stock as the mode selector??? Is there a separate switch there or do I push/pull or rotate the shaft? I don't see a separate switch there.
Old Mar 25, 2008 | 07:23 PM
CTDriver's Avatar
seems like everyone has issues with the display cluster and lines.
Old Mar 25, 2008 | 09:07 PM
thepirate's Avatar
its a button on the bottom of the stock....just push it. my car has the same problem with broken lines in the computer screen...i just keep mine turned off.
as for your cruise control, you have to push a button in on theLEFT stock, i dont thinka light comes up and says its engaged. just let your foot off the gas....
Old Mar 25, 2008 | 09:13 PM
sineo's Avatar
A lot of B5s have issues with cruise control. There are several possible causes (bad stalk is pretty common), but what fixed it for me was removing the module and re-wetting the joints on the circuit board with a heat gun. Okay, I didn't do that myself, I had it done. Try that before you spend any money on a new stalk.
Old Mar 25, 2008 | 09:26 PM
CTDriver's Avatar
wow re-wetting I think you mean re-soldering the joints.
Smedley
Apr 27, 2013 07:32 PM
stroker7.3
Mar 8, 2011 11:51 PM
LB2007
Feb 12, 2007 03:48 PM
jbracci
Feb 8, 2007 01:38 AM
Mikeoh
May 9, 2006 08:54 AM
