Rai 3" Test Pipe owners come, CCA4
Old May 11, 2013 | 02:39 PM
Pbcrazy's Avatar
Default Rai 3" Test Pipe owners come, CCA4
Cca4 you're in the title because I think I remember you having one.
Basically I installed this last night and the pipe-turbo went on easy. The 3 studs that go onto the downpipe are a completely different story, I think I have them all tight but when I took it out for a spin it had the worst f-ing sound I have ever heard. It sounds like a combination of a motorcycle, a lawn mower, and a riced out straight pipe Honda. The turbo spools loud as hell which I like but the other sound I can't handle. Does this sound like what you guys have?? Or is it leaking at the downpipe-test pipe connection?? Previously my scorpion cat-back had a deep quiet tone which I like, I don't like a super loud ricey exhaust. Please help, I hate it soooo muchhhh
Old May 11, 2013 | 09:32 PM
Pbcrazy's Avatar
Never mind, I put it up on a lift and redid it and now it sounds almost like it did before, just a little louder with more turbo
Old May 12, 2013 | 12:09 AM
CCA4's Avatar
Sounds like you had a loose bolt someplace causing an exhaust leak. Pretty sure I have a small exhaust leak now that you mention it. Glad you got it sorted!
Old May 12, 2013 | 09:53 AM
Pbcrazy's Avatar
Exactly what it was, half of the test pipe was tight while the other half was wide open. Worst sound ever.
Old May 12, 2013 | 10:22 AM
CCA4's Avatar
Yeah it sounds like a weed whacker or something lol. Glad you got it sorted. I gotta get under there and check the nuts on mine again.
Old May 12, 2013 | 12:48 PM
Pbcrazy's Avatar
Do it, easy with a full car lift, nearly impossible without (atleast in my case).
If anybody is reading this that is on the fence(like I was) about doing a test pipe, do it!! It sounds so good, and performs even better. Definitely helps with my rediculous underhood temps too
Old May 12, 2013 | 12:58 PM
CCA4's Avatar
Yeah I wrapped mine with titanium header wrap and then slopped on a bunch of that hi temp silicone spray. For starters it stops the wrap from unwrapping, and it helps seal in the heat. Not as good as a full ceramic coating, but it's better than nothing.
And you're right, anything relating to the downpipe is a pain in the *** without a lift. I do it with ramps and jack stands and I want to kill myself by the time I"m done lol
Old May 12, 2013 | 01:18 PM
Pbcrazy's Avatar
Mine is just painted with vht flameproof stuff, doesn't do heat reduction but its still much cooler then the cat was. If I thought about it I probably should have wrapped it but there is no way in hell I'm taking it back off to do it haha
fst99ls1
May 25, 2011 11:08 PM
whiteaudiguy
10
Sep 21, 2009 04:25 PM
Audi1.8t
9
Feb 6, 2009 12:38 PM
powersmokin
Apr 10, 2008 10:49 AM
greenday
Nov 29, 2005 03:43 PM
