Raising the WHP bar
Old 02-08-2009, 11:24 PM
Mike-2ptzero's Avatar
Default Raising the WHP bar
Well here are the results from this weekends dyno runs at the 034 dyno day.
Old 02-08-2009, 11:37 PM
A4speed's Avatar
those are some sick #'s! i love your setup!
what is q16 fuel?
Old 02-09-2009, 12:00 AM
what is q16 fuel?
A new race fuel from VP. It is the same octane as their C16 but is oxygenated. Testing has shown that it makes more power then C16 since about 4-6% more fuel needs to be used to stay at the same AFR.
here is the specs for Q16
NEW! Q16
Q16 will work well in any drag racing or circle track application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating.
Color: Yellow
Oxygenated: Yes
Motor Octane 116
Research Octane: 120+
Specific Gravity: .716 at 60° F
Old 02-09-2009, 12:02 AM
A4speed's Avatar
but regular gas 110 octane performs better then the q16 116 octane stuff?
Old 02-09-2009, 12:44 AM
Staticclism's Avatar
Sweet. That is one heck of a setup. Nice work!
Old 02-09-2009, 12:57 AM
Jc61990's Avatar
if thats the dyno #s im scared to see the track numbers
Old 02-09-2009, 01:16 AM
The 116 octane fuel is way better seeing that it has a much higher octane rating, thats why I made 50 more whp on the Q16 vs the 110 pushing the same boost level and being able to run more adv timing.
With any fuel, the car must be tuned for that set octane. Throwing higher octane into a car is not going to make more power unless the tune is changed.
Old 02-09-2009, 01:20 AM
A4speed's Avatar
you should switch it and say q16 vs 110 cuz i just followed the numbers straight down. i knew it didn't make sense but thats why i asked lol. that is a crazy difference though, and its awesome! think you'd get in the 9's with that in the 1/4 mile?
Old 02-09-2009, 01:50 AM
kriptonik's Avatar
God damn!
Very impressive.
Old 02-09-2009, 11:37 AM
Jeff's Avatar
Zombie Defense Force
slap that hta35 on there and see what kind of numbers you get. after that you should try out the htat37r
Quick Reply: Raising the WHP bar
