Raising the WHP bar
Old Feb 9, 2009 | 12:43 PM
Mike-2ptzero's Avatar
Originally Posted by Jeff
slap that hta35 on there and see what kind of numbers you get. after that you should try out the htat37r
HTA37r was a huge waste and I dont even think FP offers that turbo anymore because it showed zero gains vs the normal turbo.
Originally Posted by A4speed
you should switch it and say q16 vs 110 cuz i just followed the numbers straight down. i knew it didn't make sense but thats why i asked lol. that is a crazy difference though, and its awesome! think you'd get in the 9's with that in the 1/4 mile?
I didn't make the dyno chart, that was done by Javad which is the owner of 034 Motorsport. He just put the higher numbers of the Q16 above the 110 numbers, I guess he could have labeled it but most people that know anything about fueling would already know that Q16 is going to make more power then the very old 110 octane race fuel.
You wish to give me $1700-$1750 to buy a HTA turbo and try it out 1 time? LOL
I am just trying to see how far I can push this GT35r before I jump to a completely different turbo/manifold setup.
Old Feb 9, 2009 | 03:35 PM
Jeff's Avatar
Zombie Defense Force
your going to a ts manifold right? what turbo will you run with that?
Old Feb 9, 2009 | 04:16 PM
less_of_me's Avatar
Hey, it was nice meeting you at the event and learning about your car. Not sure if you remember me.....I had the santorian a4 with the ko3 there. Props to you for your car.
Anyway, I was wondering how you uploaded your dyno chart??? I can't save it to photobucket.
Old Feb 9, 2009 | 05:27 PM
I upload/host all of my pics on another car forum that is based in Nocal.
You can also upload your pictures here on this forum in the Photo Gallery page.
Old Feb 9, 2009 | 05:29 PM
Yes. The S300 91-79 which is basically the new name Borgwarner gave their S366 with the extended tips.
Old Feb 9, 2009 | 07:31 PM
Jeff's Avatar
the S300 91-79 is comparable to a gt40r? what kind of power are you expecting?
Old Feb 9, 2009 | 08:02 PM
MrFlippant's Avatar
Jesus God. That sounds like fun!
Old Feb 9, 2009 | 08:17 PM
  #18
hiwords's Avatar
you don't have security or immobilizer do you? ; )
Old Feb 9, 2009 | 08:53 PM
  #19
Better, the car doesn't start without my finger print. LOL
Just one look at trying to get into the car will make people just walk away. So unless you are 150 lbs or lighter you might as well cover your self with butter to get in the driver seat.
Old Feb 9, 2009 | 08:55 PM
  #20
Pretty much. It is a 82 lbs/min turbo.
The S300X 91-79 is the byproduct of BorgWarner/Airwerks' engineering efforts to deliver massive boost performance with excellent fitment. This turbocharger is one of the highest power and fastest responding turbos that fits in a true street car with Air-Conditioning. This is the largest, most efficient and highest power T4 twinscroll turbocharger available in a midsize frame with a 4" inlet compressor housing. It uses a 7-blade Extended Tip compressor wheel w/ 66mm inducer & 91mm exducer rated at 82lb/min. 4" Ported shroud Inlet, 3" outlet compressor housing. Turbine side is a 79mm inconel turbine wheel on a 4340 steel shaft. It uses a .91 A/R T4 twinscroll turbine housing, and can be easily converted to a singlescroll T4 .88 A/R by swapping the housing or ordering it this way. Optimum for use in very high power street cars ~550-830+whp applications that can not fit larger than a 4" inlet, certain AC compatible applications and twinturbo V6 or V8 non-AC engines. Journal Bearing and Oil Cooled only (watercooling and BB CHRA not applicable). FULL RACE RECOMMENDS MODIFYING THE TURBINE HOUSING TO 3" VBAND. (this allows for fitment identical to 40R, letting you swap between any t4 turbocharger with 3" vband outlet and guarantees perfect fitment to Full-Race turbo kits)
