ran into some problems
I was trying to replace the crankcase vent hose on the right side of my 1.8t. I am having trouble getting it seated in the hole correctly. Also is the c clamp supposed to go over the ridge on the hose. any advice. this is the piece in question
Home Page > Search > 06A103213F > ES#2515512 Crankcase Breather Hose / Tube - 06A103213F
it may still work, i have used it on those tubes before. i replaced that on a customers car a few months back and it fought me, the carb cleaner will lubricate it without damaging it like oil or grease will. hope it helps.
I still think you have some old hose/o-ring left inside the hole. Double check , it is easy to overlook. Ask me how i know?
no the old o ring was no longer in the hole i know this because i took it out and was holding both the new and old o ring in my hand. the tube sent to me was bigger in diameter than needed. so if you try and put a bigger circle in a small circle= it wont fit.
Smokin Tubes
Feb 5, 2012 10:11 AM
commedecargons
Nov 9, 2005 06:43 PM
