really annoying indicator problem
Old Nov 22, 2012 | 06:02 PM
Davidiot's Avatar
Default really annoying indicator problem
Hi,
car : A4 1.8ts quattro MY:2000
My indicator will not engage properly, less than 1 out of 10 times I try engaging it it will produce 1 flash then die, most times the little green arrow barelly lights up for 1 tenth of a second and the indicators never flash. I tried changing the combo switch, this did not solve my issue,
Anyone had the same problem? How was it solved?
Thanks
Old Nov 23, 2012 | 09:14 AM
Davidiot's Avatar
anyone ?
Old Nov 23, 2012 | 01:42 PM
rx7efini's Avatar
Im not really sure what you mean by combo switch but it sounds like you blinker relay is bad. the relay is in your hazard switch I had the same problem with my car and I just had to replace the hazard button, which fixed the problem.
Old Nov 23, 2012 | 04:12 PM
Davidiot's Avatar
Thanks for your reply, I forgot to mention, the hazards work fine, is it still likely that the problem is in the relay, by combo switch I mean the part where the levers for the indicator and lights attach, .
Old Nov 23, 2012 | 07:22 PM
Mad Cow's Avatar
The hazards are a different relay. I managed to fix mine by cleaning out the contacts on the relay, you'll see what to do when you take apart the hazard switch.
Old Nov 24, 2012 | 05:33 AM
Davidiot's Avatar
Terrific thank you ! So I take the center console apart to get at it and spray some electronic cleaner and wipe and maybe it will be operational again? Anyone know of any pictures or instructions on how to take it apart and what it will look like?
Old Nov 24, 2012 | 08:46 AM
jonbonesjones's Avatar
Moderator
2000 right? pop the top piece of trim off aka the hazard trim. the the hazard witch has tabs you push and pop! not that hard once you see it.
Old Nov 24, 2012 | 11:38 AM
rx7efini's Avatar
heres a video of how to take it apart
Old Nov 25, 2012 | 09:11 AM
Davidiot's Avatar
Thanks guys, extremely useful, it will be nice to have my indicators operational again, I feel like an unbelievable idiot driving around not indicating.
Old Nov 25, 2012 | 09:36 AM
Moderator
^^^^wonder if the rest of America who have working blinkers feels the same way ^^^^
ballins4
Dec 6, 2010 01:55 PM
xiaokai
Sep 17, 2010 07:21 AM
DevinA42003
Jul 24, 2008 12:35 AM
bitjanitor
Jul 3, 2007 10:47 AM
